Take part and winProducts of the year 2024 - you are in demand!
We are looking for the 'Product of the Year 2024'! We have published over 600 products over the past year and now they have been decided: We present the nominations in 12 categories in which you can vote for your personal favorite!
07 - Häwa: The optimal cobot workstation
Häwa has identified three housing variants for cobots to meet most market requirements. Simple base frames with a simple design are the entry point into the world of cobot workstations. They comply with protection class IP55, have doors at the front and rear and are equipped with a filter, fan and mounting plate. Thanks to the IP55 requirements, the interior can be separated. The body is reinforced at all corners and edges. This type of frame is available in a choice of dimensions with fixed castors or adjustable feet and handles. The worktop can be made of aluminum, aluminum groove profile, wood or another type of construction. Robot tables are more complex in design - for example from the 'X-frame' modular system. In the robotic table variant, the structure is based on the components from the modular system and the dimensions are derived from the standard dimensions of the horizontal and vertical struts. These enclosures also have a mounting plate, fan and filter and are manufactured to protection class IP55. Various door systems, plug-in doors, panels and Makrolon panes are optional.
