Take part and winProducts of the year 2024 - you are in demand!
We are looking for the 'Product of the Year 2024'! We have published over 600 products over the past year and now they have been decided: We present the nominations in 12 categories in which you can vote for your personal favorite!
06 - Ziehl: Monitors up to six sensors simultaneously
The temperature relays type TR660IP from Ziehl monitor up to six sensors simultaneously for up to seven limit values. Different sensor types, for example PTC thermistors, Pt100, Pt1000 or PTC, can also be connected and evaluated. Applications include the monitoring of motors, generators or transformers. The device is also suitable for use as a 2- or 3-point controller with additional alarms for over/under temperature and as a differential temperature monitor. Numerous preset programs simplify commissioning, for example transformer protection with/without core temperature monitoring and with/without fan control. Operation takes place on the device or with the built-in web server via Ethernet. Temperature differences and the rate at which the temperature rises can be monitored. The temperature curve and history are recorded. The network connection is made via Ethernet TCP/IP and values are queried via Modbus TCP.
