Take part and winProducts of the year 2024 - you are in demand!
We are looking for the 'Product of the Year 2024'! We have published over 600 products over the past year and now they have been decided: We present the nominations in 12 categories in which you can vote for your personal favorite!
4 of 9
Products of the year 2024 - Measurement technology
© Thyracont
03 - Thyracont: Preventive maintenance
The Smartline vacuum transmitters from Thyracont measure in the range from rough vacuum to high vacuum and support the control of industrial vacuum processes. In addition to the classic, analog 0 to 10 V output signal, digital interfaces such as RS485, Ethercat or Profinet enable connection to intelligent process control systems. Preventive maintenance via the Profinet interface enables direct integration into an existing Profinet network with a PLC, which can also take over the entire monitoring of the process. The Profinet modules are MRP-capable, have a high speed with low power consumption and can be updated, according to the manufacturer. In addition to the measured values, the user can also evaluate data on sensor wear, the time of the last readjustment and the number of operating hours. This makes it easier to plan maintenance intervals, procure any necessary spare parts in good time and optimize system running times. All parameters are also available in the 'Thyracont VacuGraph' software.
Directly to the survey
4 of 9
