Take part and winProducts of the year 2024 - you are in demand!
We are looking for the 'Product of the Year 2024'! We have published over 600 products over the past year and now they have been decided: We present the nominations in 12 categories in which you can vote for your personal favorite!
4 of 9
Products of the year 2024 - Electromechanics
© IMS Connector Systems
03 - IMS Connector Systems: Connector for digitalization at field level
IMS Connector Systems has developed an intelligent connector with a Bluetooth interface in M12 format that transfers sensor functions previously installed in machine modules and components to the connection technology. With SmartMod, machine and system operators can continuously monitor the values for voltage, current and power as well as the PCB temperature. Impairments to the power supply caused by cable kinks, cable breaks or a lack of power supply are detected at an early stage and can be clearly localized. This makes the connector suitable for condition monitoring of heavily used cables such as energy chains for industrial robots and production systems or for connecting measurement components with particularly small designs. As existing cabling, pin assignments and communication protocols can be used unchanged, the connector is also ideal for retrofit measures. The measurement data can be transmitted via Bluetooth over distances of up to 40 m indoors and 100 m outdoors.
Directly to the survey
4 of 9
