Take part and winProducts of the year 2024 - you are in demand!
We are looking for the 'Product of the Year 2024'! We have published over 600 products over the past year and now they have been decided: We present the nominations in 12 categories in which you can vote for your personal favorite!
3 of 9
Products of the year 2024 - Electromechanics
© Binder
02 - Binder: Power and signal interface with quick lock
The Power Bayonet Connector PBC15 from Binder is suitable for the power supply and signal connection of devices via a single cable. The size of the connector corresponds to an M15 thread. It is particularly suitable for supplying power to three-phase motors or frequency converters and has three voltage contacts, two additional contacts for signal transmission and a PE protective contact. The quick-release fastener enables reliable locking with a quarter turn. The conductor connection is made via screw terminals. The connector is initially available as cable sockets and cable plugs that can be assembled, each as an unshielded or shielded version. Thanks to the rated values of 630 V and 16 A for the power interface, the circular connector is suitable for supplying power to small to medium-sized drives. With rated values of 63 V and 10 A, the signal contacts can be used to control brakes, for example, or to query operating values such as temperatures.
Directly to the survey
3 of 9
