SPS IPC Drives 2017New products in Nuremberg
What new products will exhibitors be presenting at SPS IPC Drives 2017? Computer&AUTOMATION provides an overview of what can be seen in the Nuremberg exhibition halls this year.
Icotek introduces the tool-free cable entry system of the KEL-Quick series. The cable entry strip is a system for inserting and sealing pre-assembled cables, hoses and pneumatic lines. The manufacturer's standard slotted grommets from the 'QT' series are used. One new feature is the end cover on the head side, which is snapped onto the assembled frame. The series is based on cut-outs for 24/16/10-pin heavy-duty connectors and cut-outs measuring 36 mm × 46 mm. Tool-free assembly is carried out either by screwing on or by snapping into the 'KEL-Snap' frame. The 'KEL-Quick-E' is also available as a single-row variant. The series is tested to IP54 and UL, among others.
