Siemens / Senseye
Andrea Gillhuber,
New Generative AI functionality in Predictive Maintenance
Siemens is releasing a new generative artificial intelligence (AI) functionality into its predictive maintenance solution – Senseye Predictive Maintenance. Using a conversational user interface, manufacturers can take proactive actions easily, saving both time and resources.
© Siemens
Through this new release of Senseye Predictive Maintenance with generative AI functionality, Siemens will make human-machine interactions and predictive maintenance faster and more efficient by enhancing proven machine learning capabilities with generative AI.
Senseye Predictive Maintenance uses artificial intelligence and machine learning to automatically generate machine and maintenance worker behavior models to direct users’ attention and expertise to where it’s needed most. Building on this proven foundation, now a generative AI functionality is being introduced that will help customers bring existing knowledge from all of their machines and systems out and select the right course of action to help boost efficiency of maintenance workers.
Currently, machine and maintenance data are analyzed by machine learning algorithms, and the platform presents notifications to users within static, self-contained cases. With little configuration, the conversational user interface (UI) in Senseye Predictive Maintenance will bring a new level of flexibility and collaboration to the table. It facilitates a conversation between the user, AI, and maintenance experts: This interactive dialogue streamlines the decision-making process, making it more efficient and effective
From predictive maintenance to prescriptive maintenance
In the app, generative AI can scan and group cases, even in multiple languages, and seek similar past cases and their solutions to provide context for current issues. It’s also capable of processing data from different maintenance software. For added security, all information is processed within a private cloud environment, safeguarded against external access. Additionally, this data will not be used to train any external generative AI. Data doesn’t need to be high-quality for the generative AI to turn it into actionable insights: With little to configure, it also factors in concise maintenance protocols and notes on previous cases to help increase internal customer knowledge. By better contextualizing information at hand, the app is able to derive a prescriptive maintenance strategy.
The new generative AI functionality in the Software-as-a-Service (SaaS) solution Senseye Predictive Maintenance will be available starting this spring for all Senseye users. The combination of generative AI and machine learning creates a robust, comprehensive predictive maintenance solution that leverages the strengths of both.
Siemens
Edge-Rack-Server in robust
Der Trend zu hyperkonvergenten Infrastrukturen macht auch vor der Fertigungs- und Auto-matisierungsindustrie keinen Halt. Siemens hat nun einen ersten Edge-Rack-Server in robuster Industrie-PC-Qualität auf dem Markt gebracht. Wie ist das Innenleben...
Siemens
Für den Eigenbedarf
Siemens betreibt an seinem Standort in Frankfurt Vertical Farming für den Eigenbedarf. Zum Einsatz kommt dabei Siemens-Technologie. Was hier im Kleinen funktioniert, ist auch ein Zukunftsfeld für die Landwirtschaft im Allgemeinen.
Im Fokus: Agriculture
Das E-Paper der Ausgabe 05/2024
Um Strategien für die Zukunft geht es unter anderem in der aktuellen Computer&Automation. Lesen Sie, welche Reformen Verbände von der Politik fordern, welche Chancen Technologien wie ChatGPT und SPE mit sich bringen und welche Rolle Roboter bei...
