Products of the year 2024
Sensors - The winners
Detect objects at 80 meters? Developed according to cybersecurity standard IEC 62443-4-2? Thinner than a bar of chocolate? No problem for the winners in the sensor technology category.
The winners of the 'Sensors' category: Holger Thissen and Silvio Sprenger (Baumer), Theresa Donner (Sick).
© Julia Bergmeister Photography / Computer&Automation3rd place - Vega
In January 2023,Vega delivered what is probably the world's first level sensor with integrated cybersecurity. The manufacturer of level, point level and pressure measurement technology wants to set an example against the increasing threat from cyber criminals. The Vegapuls 6X radar sensor is unremarkable on the outside. But what the customer receives is something different from the level sensors previously available on the market. For the first time, the sensor comes with additional integrated system protection. It was developed in accordance with the cyber security standard IEC 62443-4-2 and therefore meets the highest standards currently available in the process industry. Vega does not want to rest on its laurels with the first IEC 62443-compliant device. With the certification as a guideline, the company will develop future products in accordance with all existing safety requirements right from the start.
2nd place in the sensor technology category
2nd place - Sick
The DT80 optical distance sensor from Sick achieves a measuring accuracy of ±2 mm, with a maximum resolution of 0.1 mm. The time-of-flight sensor can reliably detect natural objects with around 90 % reflection at a distance of up to 80 m and measure their distance to the sensor. The laser class 2 sensor also achieves a range of 14 m on deep black surfaces with only 6 % reflection. According to the manufacturer, 'Icons inside' and user-friendly menu navigation ensure intuitive setting and operation of the distance sensor via the TFT color display. Alternatively, the sensor can also be adjusted to the respective application via IO-Link or with the help of the 'Sopas' software.
Theresa Donner from Sick with the award for second place in the "Products of the Year 2024" readers' poll.
© Julia Bergmeister Photography / Computer&AutomationFour LEDs visualize operating and switching statuses. Thanks to its dimensions of 65 mm × 33 mm × 57 mm (H×W×D), the sensor is space-saving. The die-cast zinc metal housing, PMMA viewing window, IP65 and IP67 protection ratings and high specified shock and vibration resistance allow the sensor to be used even under harsh operating and environmental conditions.
1st place in the sensor technology category
1st place - Baumer
With the IF250, Baumer presents a flat inductive sensor with a height of just 6 mm that can detect objects at a distance of up to 12 mm. The inductive sensor complements the company's portfolio of inductive sensors in a compact design, which ranges from cylindrical subminiature sensors (from a diameter of 3 mm) up to size M30 with a switching distance of up to 24 mm. According to the manufacturer, one advantage of the flat housing is the increased safety reserve: the inductive sensor can be mounted at a greater safety distance from the object and is optimally protected even in critical applications.
Holger Thissen and Silvio Sprenger (from left) with trophy and certificate.
© Julia Bergmeister Photography / Computer&AutomationThanks to its compact size, the sensor is suitable for new machines and for retrofitting where no sensor was originally planned. Metal sleeves instead of fragile plastic holes and a mounting kit for easy attachment to pipes ensure secure and robust mounting. The sensor is available as a proximity switch with PNP or NPN output or as a measuring version with a digital IO-Link interface. Simple parameterization options are also available via IO-Link, as well as comprehensive diagnostic data such as histograms, temperature or switching cycles.
