Fraunhofer IPA
On the way to the smelling machine
Fraunhofer IPA is developing a technology for the automated production of cell-based biosensors. Such sensors could then give machines a sense of smell, for example.
To determine the right odor receptor for a specific application, several thousand receptors and their combination must be screened. This can only be done economically in an automated process.
© Fraunhofer_IPA
The platform will initially be validated on a product from the Californian start-up Koniku. However, it should later also be usable for other applications. Martin Thoma, project manager at the Fraunhofer Institute for Manufacturing Engineering and Automation IPA in Stuttgart, summarizes the innovation as follows: "We are basically developing a generic tool that should make it possible to produce cell-based biological sensors for industrial use in the medium term."
To enable the targeted development of a commercially viable product, Fraunhofer IPA will develop a screening process for receptor selection and the reliable automated production of so-called transfected cells - cells into which foreign DNA or RNA is introduced. The company Koniku has been cultivating such cells for several years, into which odorant receptors are introduced on small autonomous optical readout units. The cells can be kept alive and functional over a longer period of time in order to detect tiny particles from the environment. However, there are still many unanswered questions in this field of research.
In order to determine the right odor receptor for a specific application, several thousand receptors and their combination must be screened. To make this process economical, a platform is required that enables cells to be automatically modified, i.e. transfected, in order to subsequently examine them for their specific reaction to odors and tastes. With such a transfection and screening platform, it would be possible to modify the cells very quickly for different odor stimuli and thus open up further areas of application, such as medical diagnostics. Other visions are aimed, for example, at robots that 'sniff out' explosives at airports or locate gas leaks.
The project is funded by the Baden-Württemberg Ministry of Economic Affairs, among others.
Automation
Change at the top of Fraunhofer IPA
The Fraunhofer Institute for Manufacturing Engineering and Automation will have a new head from January 2020: Prof. Alexander Sauer, IPA Division Director of Resource-Efficient Production, will support Managing Director Prof. Thomas Bauernhansl.
Fraunhofer IPA
The digital value stream analysis
A research team from Fraunhofer IPA is digitizing value stream analysis together with the Stuttgart-based software provider Ifakt. This should enable this optimization method to be carried out in the future with significantly less effort and almost...
