Micro-Epsilon
Confocal sensors for series integration
The 'confocalDT IFD2410' and 'confocalDT IFD2415' confocal compact sensors represent a new generation of sensors from Micro-Epsilon.
© Micro-Epsilon
The compact sensor systems from Micro-Epsilon have an integrated controller, which simplifies installation. Several measuring ranges and accuracy classes make numerous measuring tasks possible, for example for series use in coordinate measuring machines, for inline thickness monitoring of flat glass and for testing electronic components. With measuring rates of up to 25 kHz, dynamic measurements can also be carried out reliably. The confocal compact sensors are housed in an all-in-one housing with integrated Industrial Ethernet. Thanks to their robust design with IP65-certified housing, the sensors are suitable for industrial series applications. They are used for distance and thickness measurement. Multi-layer measurements of up to five layers can be carried out on transparent materials. The active exposure time control of the CCD line allows fast and stable measurement on different surfaces.
Micro-Epsilon
Confocal chromatic precision sensor
The confocal chromatic sensor 'IFS2407-1.5' expands Micro-Epsilon's 'confocalDT' sensor portfolio and is used for high-precision displacement and thickness measurement. The sensor has a measuring range of 1.5 mm with a base distance of 17 mm.
Micro-Epsilon
