Moxa - Security basics - Part 3
Prime example of a cybersecurity strategy
An operator of decentralized energy resources (DER) has sustainably mitigated its cybersecurity threats with a comprehensive strategy. The example can serve as a guide for other companies to secure their systems. Part 3 of the series.
The company's first step was to understand the architecture of its DER system and identify vulnerabilities in order to identify and mitigate threats. In a detailed process, the company cataloged its cyber-physical components such as photovoltaic systems, battery storage systems, intelligent inverters with their control units and the important communication networks for data and command exchange. In a top-down approach, the system components were then mapped from an architectural overview down to the domain-specific features. Diagram tools visualized the system connections and helped to identify interaction points and weak points. This inventory and mapping covered the major DER device categories and formed the basis for the subsequent phases of threat modeling and mitigation. It clearly revealed the attack surface and the basis for a cybersecurity strategy tailored to the specific needs of the organization.
Subsequently, a large part of the architecture was already segmented. This was helpful for threat modeling and investigating vulnerabilities in the device firmware, physical security and network connections. To assess the impact of DER integration on network stability, communication protocols and interactions between third parties were analysed for data integrity and unauthorized access risks.
Identify and analyze threats
After gaining a basic understanding of the system architecture, the next step was to identify and analyze potential threats in detail across the company's entire ecosystem of distributed energy resources. The focus was on unauthorized remote access, firmware tampering, data breaches, denial of service attacks, supply chain vulnerabilities and man-in-the-middle attacks. The following attack scenarios, which could jeopardize the integrity, availability and confidentiality of the DER system, were examined in detail:
- Direct attacks on devices: Unauthorized access to smart inverters and DER controllers to change their functionality or disable them.
- Malware : Threats from malware introduced directly or via networked systems, posing a significant risk to business continuity and security.
- Unauthorized control: The risk of external entities tampering with DER devices to alter energy generation or storage.
- Attacks on networked systems: Vulnerabilities of networked infrastructures, for example smart grids, and their potential indirect impact on DER operations.
- System administration: Human error or inadequate cybersecurity practices that can lead to system vulnerabilities'.
There were also specific challenges posed by DER systems:
- Island operation: Particular attention was paid to island operation, in which DER systems continue to be operated in isolation from the main grid. This can lead to destabilization of the grid or damage to the equipment.
- Shared administration: The complexity of distributed ownership and control of DER assets required a sophisticated approach to security management across stakeholders.
- Cyber-physical interdependencies: The potential for cyberattacks to directly impact grid stability and reliability due to the close interdependence of physical operations and cybersecurity was considered in particular detail.
All threats were categorized in a structured threat modeling process in order to be able to comprehensively assess the vulnerabilities in the DER ecosystem in the next step.
Threat modeling software tools were used to develop detailed DER system models that identify potential vulnerabilities and the resulting threats. In interactive sessions with the software tools, the attack vectors and an in-depth assessment of the potential impact of security breaches could be visualized very clearly.
Reading tip: Read the previous parts of the article series "Cybersecurity basics: |
The scenarios assessed also included the risks of unauthorized firmware updates for smart inverters and the possibility of causing DER devices to perform unintended actions through fake control messages. The risk of denial of service attacks aimed at rendering smart inverters inoperable and interrupting energy distribution was also considered.
The detailed identification and analysis of potential threats provided our client with a very accurate picture of the cybersecurity landscape of their DER ecosystem. A careful approach to threat modeling is critical to developing strong security measures that are tailored to individual vulnerabilities and challenges and ensure a comprehensive cybersecurity strategy.
Assessment of the weak points
In the next step, the team meticulously researched the scenarios that could jeopardize the critical networks in order to find out how the integrity, availability and confidentiality of the DER systems can be protected.
The main cause for concern was the vulnerability of smart inverters and DER controllers to unauthorized access that could alter their functionality or disable them. Robust security measures that prevent unauthorized intrusion and manipulation provide a remedy.
The infiltration of malware into the DER system also proved to be a major threat. Whether through direct attacks or indirectly via connected systems, malware can disrupt operations or serve as a door opener for subsequent attacks. This highlighted the importance of comprehensive security protocols to detect and mitigate the risk of malware intrusion.
Another risk is posed by external parties who gain unauthorized control over DER devices in order to manipulate energy generation or storage. Strict access controls and authentication mechanisms can protect against this.
Given the interconnected nature of modern DER systems, vulnerabilities in connected infrastructures, such as smart grids, are a potential indirect threat to DER operations. This interconnectedness requires a holistic approach to security that encompasses all aspects of the network.
The team also investigated how human error or inadequate cybersecurity practices can lead to vulnerabilities in the system. The findings highlighted the need for ongoing training and awareness programs to reduce the risks posed by poor system administration.
Particular attention was paid to the phenomenon of islanding, which could be maliciously exploited to destabilize the network or damage devices. Advanced detection and management systems can prevent unauthorized islanding and thus ensure grid stability.
Prioritization and implementation
To effectively tackle the complex challenges of cybersecurity, the customer has implemented a series of security measures step by step. This ensures that each layer of defense specifically covers the identified vulnerabilities and threats and contributes to strong cybersecurity.
Cybersecurity governance framework
The first step was to introduce a cybersecurity governance framework. The definition of clear roles, responsibilities and accountability frameworks laid the foundation for all subsequent cybersecurity initiatives. This early step was crucial in overcoming the challenges of split administration and harmonizing measures across different administrative areas to achieve a unified security strategy.
Risk assessment
In the next step, the team carried out a thorough risk assessment. The potential vulnerabilities and threats identified were prioritized according to the severity of the threat so that resources could be optimally allocated to mitigate the risk.
Network segmentation and access control
By implementing network segmentation and access control, Moxa has significantly reduced the system's attack surface. The separation of critical system components and strict access controls directly reduce the risks of direct attacks and unauthorized access.
Securing the communication channels
The protection of communication channels includes the encryption of all forms of communication within the system. This ensures the confidentiality and integrity of the data and effectively protects the system against man-in-the-middle attacks and unauthorized access attempts.
System updates and patch management
Regular system updates and patch management keep all system software and firmware up to date. This eliminates known vulnerabilities and significantly reduces the risk of malware infections and direct attacks on the devices.
Monitoring and anomaly detection
To protect against a wide range of threats, Moxa's MXsecurity network security management software was used as the basis for continuous monitoring and anomaly detection. This allows potentially suspicious activities or anomalies that indicate security problems to be detected at an early stage.
Response and recovery protocols
In order to be prepared for potential cybersecurity incidents, the cybersecurity team developed and tested response and recovery scripts in Moxa's Network Management System. By defining specific procedures for rapid response and recovery, rapid action to contain and resolve problems for all identified attack types is guaranteed in the future.
Multi-factor authentication and encryption
Multi-factor authentication and encryption for system access and data protection counteracts unauthorized access and data breaches and creates an additional layer of security. It is important to implement encryption and multi-factor authentication in the system.
Testing of security protocols
To ensure the effectiveness of the security measures implemented, the team regularly carries out routine tests in a controlled environment. They show whether the security protocols work as intended and do not lead to new vulnerabilities.
Review and optimization of cybersecurity measures
To maintain the system's defenses, cybersecurity measures are continuously reviewed and optimized. The team regularly reviews and updates the cybersecurity protocols so that they are always in line with new threats and evolving system requirements. Only then will they be resistant to a dynamically changing threat landscape in the long term.
Monitoring and continuous improvement
In addition, the DER operator has implemented a robust framework for continuous monitoring and improvement measures. This is essential to ensure security even in the face of new threats and technological advances. To this end, the company relies primarily on real-time monitoring. This gives it an insight into the cybersecurity status of the system and enables it to detect potential threats at an early stage. This provides effective protection against numerous threats, including malware and unauthorized access.
The customer has also committed to regularly updating the security protocols and systems. In doing so, it is guided by the latest research findings and threat data. This ensures that the DER system is also protected against new threats and that vulnerabilities are rectified immediately.
A SIEM system (Security Information and Event Management) is currently being examined for continuous monitoring. Such a system provides a holistic overview of information security through log management, event correlation and real-time alerts. Advanced SIEM tools for monitoring and analyzing security logs from the DER system detect security incidents at a very early stage, enabling a rapid response.
Through this comprehensive strategy from threat modeling to remediation implementation, the company has methodically strengthened the cybersecurity framework of its DER system and developed a robust defense strategy that can address both current and future security challenges in the DER space. At the same time, it also ensures compliance with best practices and regulatory requirements.
