Expert-Tünkers
7th axis guided around the corner
The 7th axis of Expert-Tünkers can be extended by an '8th axis' using a turning station with integrated turntable and can thus be guided around the corner, which extends the range and mobility of robots.
© EXPERT-TÜNKERS
Thanks to the modular design, several axes with individual output angles and lengths of up to 30 m can be combined according to customer requirements. The base consists of a solid base frame with ground and hardened guide rails that move the carriage on top. The transfer to a second axis is just as smooth. Depending on the configuration, the system can accommodate and transport standard robot systems, welding guns or other handling devices weighing up to 4 tons using an adapter plate. According to the supplier Expert-Tünkers, this is done with an acceleration of 1.5 to 3.8 m/s2 and a speed of 1.5 to 2.5 m/s.
The system can be connected to standard robot systems and their control systems. A specially developed energy chain ensures the energy supply along the entire route, even when turning stations are integrated.
