tci
Touch panels can be operated intuitively
With the E07A and E10A, tci presents two touch panels for industrial applications, for example in the areas of production, logistics and energy management. Android is used as the operating system.
© tci
The HTML5 AutomationBrowser is compatible with all common web applications and can therefore be used universally. The widescreen display with capacitive multi-touch (PCT) can be operated intuitively, just as users are used to from a smartphone or tablet. The panels' TFT color display offers a native resolution of 1024 x 600 pixels.
According to tci, the slimline web panels are equipped with an easy-to-clean continuous real glass front with IP54 protection and a lightweight, industrial-grade plastic housing. They can be mounted in a control panel, in a switch panel or via VESA. The panels do not have any rotating parts or fans. The 10-inch version is also available as a PLC operating panel (E10A-XS) for common control systems.
Rigol Technologies
Operation via touchscreen
Rigol Technologies is expanding its real-time spectrum analyzers with the RSA3000-E economic series. The devices are based on 'UltraReal' technology, which makes it possible to carry out real-time measurements, among other things.
Eaton
Operation even with gloves
Eaton is adding a fully graphic touch panel from the XV102 series to the 'easyE4' product family. The 3.5-inch touch panel with color display was developed for the visualization and operation of applications based on the 'easyE4' control relay.
Rafi
Placed directly on the touchscreen surface
Rafi equips the 'Glasscape' touchscreens with haptic operating solutions: The Flexscape One and Flexscape Wheel control elements are placed directly on the touchscreen surface and enable safe function control without visual contact.
Touch monitors
Front protected to IP65
Advantech launches the IDS-3300 industrial touch monitor series with IP65-protected front and screen sizes of 10.4 inches, 15 inches and 19 inches. The monitors are equipped with robust front metal frames developed in-house.
