Current productsNews about operating and monitoring
What is the optimum operating unit for industrial users? What is happening on the market? Computer&AUTOMATION presents a selection of new products from the operating & monitoring sector as a series of pictures.
6 of 29
Robust touch operating device from R. Stahl
© R. Stahl HMI Systems
Robust touch operating devices from R. Stahl HMI Systems enable machine-oriented operation and visualization of applications in hazardous areas. The ET-208 operator interfaces, which are approved for zones 1 and 21, have a 7-inch widescreen and a hardened glass surface and are protected on the front in accordance with protection class IP69. This means they meet FDA requirements for cleanroom suitability, as the front panel can be cleaned with high-pressure cleaners. The HMIs have a V2A stainless steel housing and are corrosion-resistant with certification to ISA-S71.04-1985, degree of severity G3, in accordance with EN 60068-2-6. They can also withstand seawater without any problems. They can be operated at ambient temperatures from -40 to +65 °C. A bright display and anti-reflective coating ensure good readability in outdoor use and in bright light. The HMIs have interfaces for Industrial Ethernet, RS422/RS485 and optional WLAN. The processor is the Cortex A8. As standard, the touch operating devices are set up with Windows Embedded Compact 7 as the operating system. The 'SPSPlusWIN' software can be used to create and edit screens, process connections and messages for the HMI devices.
6 of 29
