Current productsNews about operating and monitoring
What is the optimum operating unit for industrial users? What is happening on the market? Computer&AUTOMATION presents a selection of new products from the operating & monitoring sector as a series of pictures.
HMI panels and POS/POI terminals are generally used for clearly defined applications that do not place high performance demands on the system; immediate operational readiness and a compact and attractive design are the main focus. ICP Germany combines these features in the 10.1 inch RISC-based Ready-to-Use Panel PC IOVU-10F with a resolution of 1280 x 800 pixels. Pre-installed on the 4 Gbyte eMMC Nand Flash, the Android 4.2.2 operating system is based on a Freescale i.MX6 Cortex - A9 Quad Core 1.0 GHz RISC processor with 1 Gbyte DDR3 SDRAM memory. The Panel PC has a scratch-resistant capacitive touchscreen (IP54), which is embedded in a slim housing (293 mm × 210 mm × 45 mm). The metal rear of the Panel PC has one GbE, two USB 2.0, one RS232/422/485 and one RS232 vertical downwards interface. A WiFi and Bluetooth controller and an SD slot with a maximum storage capacity of 32 GB are also integrated. Other features include flexible mounting options (wall, panel, stand and arm mounting), an input voltage range of 9 to 30 V(DC) and an operating temperature of 0 to +40 °C.
