Current productsNews about operating and monitoring
What is the optimum operating unit for industrial users? What is happening on the market? Computer&AUTOMATION presents a selection of new products from the operating & monitoring sector as a series of pictures.
5 of 24
2_New panels from Wago Kontakttechnik
© Wago Kontakttechnik
The e!Display 7300T panels from Wago for web-based applications are suitable for displaying visualizations from the Codesys 2 development environment as well as from the e!Cockpit engineering software (based on Codesys 3). Like the company's controllers, they are operated using web-based management. HTML5 is available for programming. A Java runtime for the Codesys 2 Web-Visu is also available. The web panel is available in 4.3 inch, 5.7 inch, 7 inch and 10.1 inch sizes. The display has a resistive touchscreen, flanked by three status LEDs that indicate the operating status and provide feedback on operation. When the user approaches the device, a sensor automatically wakes it up from standby mode. The same sensors detect the current lighting conditions, according to which the display brightness is automatically adjusted. Alternatively, the brightness can be adjusted manually. The panels can be easily snapped directly into the switch cabinet using fixing clips. IP65 protection is achieved at the front using clamping elements. In addition, the existing Vesa connection enables mounting on a swivel arm or stand outside the control cabinet.
5 of 24
