Current productsNews about operating and monitoring
What is the optimum operating unit for industrial users? What is happening on the market? Computer&AUTOMATION presents a selection of new products from the operating & monitoring sector as a series of pictures.
With its new touch panel series, Electronic Assembly offers both capacitive and resistive touch with identical functionality. The display automatically acknowledges inputs via the touchscreen with various signal messages, the change of an output level or with data via one of the built-in RS232, SPI or I²C interfaces. Its scratch-resistant and dirt-repellent surface is designed to ensure a long-lasting, clear appearance. All operating elements can be dynamically adjusted during operation and the panels are available in 3.2 inch, 4.3 inch, 5.7 inch and 7 inch sizes, depending on the installation situation. The displays can be soldered in, screwed in or plugged in. They also each have eight digital inputs and outputs as well as two programmable analog inputs. They are controlled via high-level language-like graphic commands. The long-life LED lighting has been specially developed for applications in industrial environments.
