Axxeron Hesch electronics
Multiple differential pressure transducer saves costs
The 'HE 5413' multiple differential pressure transmitter from Axxeron Hesch offers up to three measuring channels with freely selectable measuring ranges in one housing.
The compact three-channel differential pressure transmitter can be put into operation quickly using the M12 connector, as the device does not need to be opened in order to be connected electrically. All settings are made using the 'EasyTool Controls 4.0' software from Axxeron Hesch. The modules of the measuring transducer are each equipped with an analog standard signal current output (4 to 20 mA) and a voltage output (0 to 10 V). Depending on the module selected, different measuring ranges from ±2.5 mbar to ±1000 mbar can be parameterized. Thanks to the modular concept, users also have the option of choosing a configuration with two instead of three measuring channels, so that they can optimally adapt the transmitter to their requirements. The measuring hoses are connected via a plug-in hose connection for hose diameters of 6 mm. A reducer for 4 mm hoses is available as an accessory.
