Data logger
Quelle: Delphin Technology | Inka Krischke,
Including OPC UA client/server interface
Delphin Technology is expanding its 'Expert Logger' series with the Type 400 with OPC UA client/server interface. The self-sufficient data logger system is thus equipped for the universal exchange of measured values at field level and for the requirements of Industry 4.0.
© Dolphin Technology
The device also has Profibus, Modbus, CAN bus and serial interfaces. PCs are connected via USB, LAN, WLAN or LTE.
The data logger is equipped with 16 universally usable, differential analog inputs for measuring mV and mA signals or any thermocouples. The accuracy is specified with 24 bits and the measuring rate with a maximum of 1000 measurements/s. The logger can also be used to measure Pt100(0) sensors in 2-, 3- or 4-wire technology or strain gages.
With a total of 24 switchable digital inputs/outputs, edges and fault events can be recorded to the microsecond or alarms can be output. A total of six analog outputs enable the control of controllers or actuators.
Measured values and limit value violations can be transmitted directly to subsystems via OPC UA. The OPC UA interface is also suitable for exchanging data with PLCs or for connecting to PCT systems.
Kistler
Solid sales development in 2025
The Kistler Group generated sales of 424 million Swiss francs in 2025. With a currency-adjusted decline of 1 percent, or 5 percent in Swiss francs, the company was able to keep sales stable compared to the previous year.
AMA Innovation Award 2025
Submit applications now
The AMA Association for Sensors and Measurement (AMA) is calling on scientists and developers from industry and research to apply for the AMA Innovation Award 2025. We are looking for research and development results in sensor and measurement...
Janitza
Management expanded
Axel Hessenkämper joined Janitza as the new Chief Executive Officer (CEO) on September 1, 2024 and is part of the management team alongside Mr. Janitza, Mr. Müller and Mr. Veidt.
