Jumo at the SPS 2022Compact level monitoring
The Zelos C01 LS from Jumo detects the level of liquids and solids and can be used at temperatures between -40 and +200 °C.
6 of 13
© Chauvin Arnoux
Chauvin Arnoux is launching the Qualistar CA 8345 for power quality diagnostics. In accordance with the IEC 61000-4-30 Class A standard, the power and power quality analyzer is intuitive to use. It enables the diagnosis and troubleshooting of an electrical installation, the testing of current consumption in accordance with EN ISO 50001 and the verification of power quality in accordance with EN 50160. The measuring device has dedicated function buttons on its front panel. It automatically recognizes current transformers as soon as they are connected. Communication is simplified by numerous integrated modes: USB, an accessible SD card, Ethernet, Wifi and web server. Users can choose to monitor and retrieve measurements remotely, in real time or with a time delay. The meter records hundreds of parameters, which are stored from period 1 to 10 (50 Hz) / 1 to 12 (60 Hz). Up to 20,000 adjustable alarms, True Inrush mode and other functions enable comprehensive power and power quality analysis.
SPS 2022: Hall 4A, Sand 226
6 of 13
