Jumo at the SPS 2022Compact level monitoring
The Zelos C01 LS from Jumo detects the level of liquids and solids and can be used at temperatures between -40 and +200 °C.
12 of 13
© Jumo
The Zelos C01 LS from Jumo detects the level of liquids and solids and can be used at temperatures between -40 and +200 °C. It can also be used in pressurized tanks or pipes. It can also be used in pressurized tanks or pipelines. Once configured, the two switching outputs can automatically differentiate between measuring medium and cleaning media or foam. Installation is carried out using a standard torque wrench. Short-circuit and reverse polarity protection provide additional safety. An antivalent circuit detects line faults such as a cable break. A firmware update profile allows the sensor to be updated while installed, minimizing system downtimes. PNP, NPN, Push Pull and IO-Link are available as output signals. A status display indicates the sensor status in accordance with NAMUR and VDI/VDE. The detector also has IP67/IP69 protection and meets the requirements of intrinsically safe explosion protection, the German Water Resources Act and electrical safety in accordance with UL.
SPS 2022: Hall 4A, Stand 445
12 of 13
