Hanover Fair 2018New products at the industrial trade fair
'Integrated Industry - Connect & Collaborate' - this is the motto of the world's most important industrial trade fair, Hannover Messe 2018. Computer&AUTOMATION shows an excerpt of the products that can be seen in Hanover in a picture gallery.
JVL Industri Elektronik A/S has further developed the integrated stepper motors of the "MIS23" series: The integrated ServoStep motors in the Nema23 flange dimension have an RS485 interface as well as optional CANopen or Industrial Ethernet. A motion controller programmable in sequence language is also available. The motors enable a microstep resolution of 409,600 steps/revolution. With the M12 connector outlets, users can decide whether they are to be used radially or axially in the application. There are three different motor sizes and two different motor types; three versions with standard high-torque stepper motors and two versions with ultra-high-torque stepper motors with 40 % more torque. The motors can be operated "stand alone" or via a controller. Eight I/Os can be individually parameterized as digital inputs/outputs or as analogue inputs. As standard, it is possible to communicate with higher-level systems via Modbus RTU or CANopen, for example. The JVL MAC protocol, which is also supported, makes it easy to set up an RS485 network with a maximum of 254 other JVL-integrated motors. The motors offer Profinet, Ethercat, Powerlink, Ethernet/IP, Modbus TCP and Sercos III as interfaces. The stepper motors are also available with Bluetooth, ZigBee or WLAN.
