Hanover Fair 2018New products at the industrial trade fair
'Integrated Industry - Connect & Collaborate' - this is the motto of the world's most important industrial trade fair, Hannover Messe 2018. Computer&AUTOMATION shows an excerpt of the products that can be seen in Hanover in a picture gallery.
Igus offers a strain relief system for energy chains in which cables and hoses are inserted into a honeycomb and then firmly sealed. Now a further developed system is coming onto the market to replace the previous variants. The CFU honeycomb strain relief replaces the cable ties frequently used in the industry to date: whereas previously each cable was fixed to the energy chain individually, with the new solution the cables and hoses are simply inserted into the honeycomb and sealed. The outer walls of the honeycomb cavities wrap gently and firmly around the cables. The honeycomb is quick to install and flexible, as new cables can be easily inserted or replaced. The further improved strain relief combines a compact design with simple and flexible filling. The strain relief can be used in both self-supporting and gliding applications thanks to its flush fit with the energy chain connection element. The vertical design allows easy scaling for individual chain widths. Different cables are inserted into the vertical rows, the system is closed and then screwed together at the top. Optional clips on the side sections connect the energy chain and strain relief. The system is currently under development for the "e-chain E4.1L".
