Yaskawa at the SPS 2022Automation, drive and control solutions from a single source
As a prelude to the growing i³ Control portfolio, Yaskawa presents the first PLC of the i³ Control complete solution: the iC9210-PN.
15 of 19
© Keba Industrial Automation
The automation system for hardware and software Kemro X from Keba Industrial Automation covers everything a machine manufacturer needs for its smart factory. All mobile and stationary panels, drives and hardware variants as well as the engineering tool are integrated. This means that several technology packages can be controlled simultaneously via the system. The platform is based on a modular system in modules that can be used like smartphone apps. This is intended to ensure simple handling and control. Modules from the manufacturer, customer-specific modules or even Linux-based standard modules can be used. Thanks to the Linux-based openness, customers can integrate their own software modules as well as software from third-party providers. This system architecture also enables the necessary inter-process communication. The solution can be used for a wide range of automation projects, such as engineering tools or simulation tools.
SPS 2022: Hall 7, Stand 470
15 of 19
