akYtec
Andrea Gillhuber,
Control portfolio expanded
AkYtec has new controllers, process displays and cloud services for industrial and building technology applications in its portfolio. The focus is on compact devices with integrated visualization and extended communication functions.
© akYtec
SPC210 - Compact controller with integrated HMI
The SPC210 programmable controller combines PLC and HMI functions in one device. It has an integrated touch display and therefore reduces the amount of hardware required in automation systems. The unit enables programming, visualization and operation directly on the device, which reduces installation costs and system complexity.
PR205 - Compact PLC for top-hat rail mounting
The PR205 model is a compact PLC with an integrated 2.4-inch IPS color graphic display (320 × 240 pixels, 65,535 colors) for DIN rail mounting. It offers Ethernet and RS-485 interfaces as well as analog and digital inputs and outputs. Programming is carried out in the free ALP software from akYtec. Typical applications are in building automation, especially in heating, ventilation and air conditioning systems.
PR225 - Programmable relay with communication interfaces
The PR225 is a programmable relay in a panel housing with a 3.5-inch graphic display. It has combined analog and digital I/O as well as Ethernet and RS-485 connections. Configuration is also carried out via the ALP development environment in accordance with IEC 61131-3 (function block diagram, structured text). Integration into higher-level systems and the connection of external modules or the akYtec cloud is possible via the integrated interfaces.
ITP15-M and ITP17 - Three-color process displays
The ITP15-M is a bar graph indicator with 10-segment display (0-100 %) and a three-color display (green, yellow, red) that supports configurable threshold values. It fits into standard 22.5 mm diameter openings and allows easy integration into control panels.
The ITP17 universal display unit can connect different sensors (e.g. for temperature, pressure, level or humidity) directly. Measured values are shown on a three-color display, whereby limit values can be freely defined between the colors.
akYtec Cloud - Remote monitoring and data analysis
The akYtec Cloud offers a free platform for web SCADA, remote control and data analysis. The service enables the secure connection of devices such as SPC210, PR205 and PR225 for real-time monitoring, visualization and control via the Internet. A virtual PLC function extends the application options to include cloud-based automation tasks.
Schaeffler
At its meeting on September 26, Schaeffler's Supervisory Board made two appointments to the Executive Board. There is also another change in the Executive Board. As a result, the Executive Board will consist of nine members from October 1, 2024...
Codesys
Virtualized Control Technology in Practice
Software determines functionality in televisions, vehicles, smartphones, and increasingly in industrial automation and industrial control systems. This development has led to the emergence of virtual PLCs (vPLCs). The following article describes how...
