Products of the year 2024
Andrea Gillhuber,
Communication & networking - The winners
TSN, fast data migration and muting are among the key features of the winning products in the 'Communication & Networking' category.
The winners of the ' Communication & Networking ' category (from left): Thomas Rönitzsch from Bihl+Wiedemann and Dimitri Philliope from BE.services with Andrea Gillhuber (Computer&Automation).
© Julia Bergmeister Photography / Computer&Automation
3rd place - BE.Services: Low-footprint OPC UA PubSub TSN Stack eTSN (enable TSN)
© BE.services
3rd place - BE.services
The low-footprint OPC UA PubSub TSN Stack eTSN (enable TSN) developed by BE.services together with Offenburg University of Applied Sciences can be ported to various platforms and components in the TSN network. It can be used on Intel or TI platforms in C2C communication as well as on platforms with a TSN-compatible Ethernet interface, for example Intel (wireless) or Renesas, as bridges or as a device implementation. The corresponding software development kit can be implemented both with an operating system and on a bare-metal platform.
3rd place for the eTSN stack: Dimitri Phillipe from BE.services accepted the trophy.
The solution is based on the following components: a resource-optimized Matrikon eFlex OPC UA stack, a proprietary IEEE 802.AS PTP stack to ensure hardware portability and independence, and a test suite environment to monitor latency, jitter and synchronization of the TSN network. The software development kit allows implementation on different platforms and supports the implementation of hardware-specific IEEE 802.1 standards. The OPC UA FX specifications for C2C are supported and specifications such as C2D are also taken into account after official release.
2nd place in the Communication & Networking category
2nd place - Weidmüller: MiBridge
© Weidmüller
MiBridge from Weidmüller enables PLC/PLS to be replaced without the need for extensive rewiring. This migration solution makes it possible to simply connect I/O cards to the existing field wiring via an adapter card so that the existing field wiring can continue to be used without restriction. The connection is made directly via the existing field wiring connector. Depending on the existing installation, MiBridge offers three different solutions for quickly replacing the PLC/PLS: bridge solution, card solution and system cabling with PLC/PLS transfer elements. With all solutions, the existing cabling is completely retained. With Card Solution, the mounting rack of the new system is added to the existing installation, allowing the new card adapters to be inserted into the existing adapters. In the case of system cabling with PLC/PLS transfer elements, only the DC cable and the PLC/PLS itself need to be replaced. MiBridge is compatible with PLC/PLS systems from different manufacturers.
1st place - Bihl+Wiedemann: ASi-5 Safety Muting Module BWU4411
© Bihl+Wiedemann
1st place in the Communication & Networking category
With the ASi-5 Safety Muting Module BWU4411 in IP67 from Bihl+Wiedemann, various muting solutions up to SIL3/PLe can be implemented efficiently. Whether cross muting or sequential muting, all the necessary sensors and safety components can be flexibly connected to the module. This means that all signals required for muting are available in one module under a single ASi-5 address. Unused inputs and outputs can be used for other applications, for example to control muting lamps or integrate push-button modules.
Delighted with 1st place: Thomas Rönitzsch from Bihl+Wiedemann.
As an alternative to processing in the ASi safety monitor, all relevant signals can also be forwarded via safe fieldbuses - Profisafe, CIP Safety, FSoE or openSafety. In the 'Asimon360' software suite, there are ready-certified muting modules for convenient parameterization for many applications; complex programming in the control system is not required.
