© Fujitsu Technology Solutions
The D3348-B ATX industrial mainboard from Fujitsu is available with Intel processors from the Xeon E5-2xx [V3], Xeon E5-16xx [V3] and Core i7 58xx/59xx series. Unlike most comparable mainboards on the market, it is not based on the X99 chipset, but on the C612 chipset from Intel. According to the manufacturer, the C612 chipset is particularly suitable for industrial applications because it supports Intel Standard Manageability and Intel vPro technology for remote maintenance as well as Trusted Execution Technology (TXT). It also offers support for Xeon processors and ECC memory. By using solid capacitors, Fujitsu can specify the D3348-B for a lifetime of 45,000 hours in 24/7 continuous operation. The product has a thermal design power (TDP) of 160 watts. It has four PCIe x16 and three PCIe x8 slots, four USB 3.0 and nine USB 2.0 ports as well as ten SATA(600) ports. As an accessory, Fujitsu offers the PCI-x8 expansion card D3352 for M.2 SSD modules, which enable high-end data transfer rates and minimal boot times.
