In a product picture series, Computer&AUTOMATION presents the latest power supply products - from desktop power supply units and insulation monitors to explosion-protected power distribution.
© Bicker Elektronik
BET-0600 from Bicker Elektronik is a desktop power supply for industrial use. In addition to three standard models with regulated single DC output voltages of +12 V (60 W), +19 V (60 W) and +24 V (65 W), other output voltages are available on request. The desktop power supply meets the requirements of the US Department of Energy (DoE) for energy efficiency level VI. The power consumption in standby mode of <0,15 W unterhalb des hier geforderten Wertes von ≤0,21 W. Als typischer Wirkungsgrad des lüfterlosen Tischnetzteiles sind 90 % angegeben. Die MTBF von >992,000 hours is achieved by the exclusive use of +105 °C premium electrolytic capacitors and a robust circuit design. The device is suitable for the temperature range from 0 to +60 °C (start from -20 °C). It has a wide-range input of 90 to 264 V(AC) (50 to 60 Hz). Protective functions such as short-circuit, overvoltage and overload protection with automatic restart are integrated. The PE protective earth connection on the primary side is connected to -Vout (secondary).
