Dura-/Mate is an IP67-tight series of plastic circular connectors with bayonet lock from Amphenol, which is protected against a wide range of environmental influences. The ergonomically designed locking system confirms the secure locking of the plug connection with a visual and acoustic signal as well as a perceptible click. Two different end housing versions, which can be screwed onto the connector housing, provide additional cable strain relief for various applications. The flange-mounted or flying lead design is ideal for high-pole applications in the commercial vehicle, agricultural and construction machinery or marine sectors. The connectors operate in a temperature range between -55 and +125 °C.
