Fimab offers an online configurator that speeds up the process of ordering an enclosure so that it is ready in ten days. Anyone accessing the online configurator can configure their desired enclosure and see the result immediately after each action. First, the material - stainless steel or sheet steel - is specified. Once the millimeter-precise dimensions have been entered in all three dimensions, the control cabinet appears spatially on the screen. It is possible to select any RAL color without extending the delivery time. The enclosure can be equipped as required using drag & drop. Holes and cut-outs for filter fans, emergency stop buttons, on/off buttons, various cable entry plates and cable glands are available; the relevant data sheets for the equipment components are stored and can be called up directly if required. The desired equipment can be positioned freely on one of the six sides of the enclosure with millimetre precision using the superimposed coordinate display. The configurator offers transparent processes, immediate feedback on every action and freely rotatable 3D visualizations. It checks all entries for plausibility and collisions between individual components are displayed immediately.
