18 of 24
Stainless steel terminal boxes made of V2A from Lohmeier
© Lohmeier
With the stainless steel terminal boxes made of V2A, Lohmeier presents a product family for aggressive environmental conditions and hygienically demanding requirements. The terminal boxes made of stainless steel 1.4301 achieve protection class IP66 in accordance with EN 60529. They retain their protective properties even in contact with cold, moisture, oils or acids and are therefore suitable for the chemical industry and food production, for example. The terminal boxes are available with a depth of 120 mm and different widths and heights between 150 and 400 mm. Fastening profiles in the base of the enclosure ensure secure mounting. The enclosure doors are fixed with captive screws. Existing holes in the rear panel facilitate wall mounting - additional embossing also enables wall mounting brackets to be attached.
18 of 24
