14 of 24
Argee from Turck
© Turck
With Argee from Turck, PLC functions can be programmed directly on the modules of the block I/O series in IP20 and IP67 'TBEN-L', 'TBEN-S', 'BL compact' and 'FEN20' from the supplier. This allows simple control functions to be outsourced to the I/O modules, which reduces the load on the central controller and bus communication. The programming environment is a web application that only requires a Windows PC with a web browser such as Chrome or Firefox. Thanks to the provider's multiprotocol Ethernet, pre-programmed modules can be used in Profinet, Ethernet/IP or Modbus TCP networks. Simple requirements can also be implemented completely independently on the block I/O modules. During programming, the inputs and outputs can be linked to Boolean operators and actions via drop-down fields in Simple mode, which corresponds to a ladder diagram editor. This makes it possible to program basic functions without knowledge of a programming language. In Professional mode, the full range of functions is available, which means that flowcharts, for example, can also be implemented without the need for programming knowledge.
14 of 24
