11 of 24
Cable entry systems from icotek
© Icotek
Icotek has had a large number of products certified in accordance with Directive 2014/34/EU and offers numerous cable entry systems for prefabricated and non-prefabricated cables that can be used for equipment group II in category 2 (zone 1 material group G, zone 21 material group D) and category 3 (zone 2 material group G, zone 22 material group D). The materials used are self-extinguishing. The divisible cable entry systems for cables with plugs also enable quick fitting in the event of retrofitting. The manufacturer's warranty for the pre-assembled cables is retained, as there is no need to solder or unsolder connectors. Cables up to 65 mm in diameter can be inserted and sealed with IP65/ NEMA 4X. With the cable entry plates for cables without connectors, cables up to 55 mm in diameter can be inserted and sealed up to IP68.
11 of 24
