Product presentationsNews from electromechanics
Connectors, cable glands, cables and wires - there are always numerous innovations for industrial users when it comes to electromechanics. Computer&AUTOMATION has summarized a selection of current products in a series of pictures.
14 of 15
Signal lamps from Marl International
© Distrelec
Distrelec has added the British manufacturer Marl International to its range of industrial signal lamps. Signal lamps from Marl are available ready for installation and connection from 2 to 48 V. The Distrelec range includes vandal-proof signal lights with protection class IP67 as well as slimline lights with a mounting diameter of just 5 mm. The nickel-plated or anodized metal housings can withstand tough conditions. The range is primarily aimed at interactive front panels in machine and plant construction, special vehicle and rail vehicle construction. All signal lights are approved for the extended temperature range between -40 and +85 °C, are vibration-proof and waterproof. In addition to the standard 12 and 24 V types, special voltages of 2, 6 and 48 V are available in each series.
14 of 15
