Escha at the SPS 2022High-pole M8 connection technology in shielded design
Sensors are becoming increasingly compact and complex. This development is increasing the demand for correspondingly compact and high-pole connectors. Escha is meeting this demand with an M8 product range in an 8-pin version.
1 of 7
© Escha
Conta-Clip now also offers the mounting rail relay bases of the 'PRS' plug-in relay system in versions with push-in connection. Thanks to the tool-free wire insertion, the sockets of the new PPRS series, which are available for relays with 1, 2 or 4 changeover contacts, significantly reduce the time required for wiring. Integrated pushers, which can be operated without special tools, are used to release the inserted wires.
The relay sockets are designed for a rated voltage of 300 V and can be flexibly configured with PRS relays for voltage ranges from 12 to 220 V(DC) or 12 to 230 V(AC) as well as the corresponding plug-in modules with LED status display. Each connection also has a test tap to check the voltage applied. The pluggable and touch-proof external cross-connection system 'AQI/PPRS' is available as an accessory for the demand-oriented distribution of potentials between bayed base modules. Other equipment options include snap-on retaining brackets that hold the plugged-in relays in place if required.
SPS 2022: Hall 10, Stand 122
1 of 7
