Smela
Linear actuators independent of the bus system
The 'LiteEco' linear actuators from Smela address applications for fixing, adjusting and moving individual motion profiles, for example in production lines, machine tools, robotics or handheld devices.
© Smela
The mechatronic system consists of a servomotor, the mechanics and integrated sensors. The ability to control with various drive controllers (motion controllers) makes the linear actuators independent of the bus system and, according to Smela, gives the user the freedom to choose the controller. The LiteEco Base series integrates all the features of its predecessor 'LE48' and supplements them with features for demanding industrial requirements. For example, the series offers IP65 and a rotatable circular connector with a quick-lock system, through which power and sensor signals are routed to the outside via a hybrid cable. In addition, a high-precision optical measuring system has been integrated into an even more compact installation space and the possibility of simple refurbishment has been created. The LiteEco Base series starts with a base stroke length of 45 mm.
Lean technology
Easy to implement
