Take part and winProducts of the year 2024 - you are in demand!
We are looking for the 'Product of the Year 2024'! We have published over 600 products over the past year and now they have been decided: We present the nominations in 12 categories in which you can vote for your personal favorite!
01 - Kunbus: New version of the industrial Raspberry Pi
Kunbus presents the RevPi Connect 4, the fourth generation of the 'Revolution Pi' and the first to be based on the Raspberry Pi Compute Module 4 (CM4). The device has a modular design, is suitable for industrial use and uses the Broadcom BCM2711 processor, a 64-bit quad-core Arm Cortex-A72 with up to 8 Gbytes of RAM. The increase in RAM has a positive effect on container applications or motion applications. The eMMC memory with up to 32 Gbyte is available as a storage medium. There is also the option of WLAN and Bluetooth connectivity via the internal or an external antenna, which is connected to the new SMA socket. A new feature is the option to connect ten instead of five I/O expansion modules to the base module via plug-and-play. There are two Gigabit Ethernet interfaces, two USB 3.2 Gen1 interfaces with transfer speeds of up to 5 Gbit/s, as well as client and server capabilities for the common Modbus RTU and Modbus TCP protocols.
