Take part and winProducts of the year 2024 - you are in demand!
We are looking for the 'Product of the Year 2024'! We have published over 600 products over the past year and now they have been decided: We present the nominations in 12 categories in which you can vote for your personal favorite!
08 - Conec: Hybrid connectors with IP67 protection class
Conec presents the hybrid connector series. The hybrid connector system combines and transmits the power supply and data transmission in accordance with Cat 5 via a specially developed hybrid cable. This single-cable technology corresponds to modern connection and interface wiring. With the angled B23 hybrid flange, it is possible to equip servo drives with an output of over 20 kW with a single-cable solution. Common to all sizes is the separately shielded four-pole data element for the transmission of Industrial Ethernet in accordance with ISO11801 Class D or signals with currents of up to 4 A. The connector is locked with a bayonet quick-release fastener, eliminating the need for a torque wrench. A quarter turn ensures a secure connection and IP67 protection. The bayonet can only be locked when the hybrid connectors are fully inserted. This is intended to reduce the risk of failure due to connectors that are not fully mated or have a defined screw connection.
