Take part and winProducts of the year 2024 - you are in demand!
We are looking for the 'Product of the Year 2024'! We have published over 600 products over the past year and now they have been decided: We present the nominations in 12 categories in which you can vote for your personal favorite!
05 - Weidmüller: Fast PLC/PLS migration
MiBridge from Weidmüller enables PLC/PLS to be replaced without the need for extensive rewiring. This migration solution enables I/O cards to be easily connected to the existing field wiring via an adapter card, so that the existing field wiring can continue to be used without restriction. The connection is made directly via the existing field wiring connector. Depending on the existing installation, MiBridge offers three different solutions for quickly replacing the PLC/PLS: bridge solution, card solution and system cabling with PLC/PLS transfer elements. With all solutions, the existing cabling is completely retained. With Card Solution, the mounting rack of the new system is added to the existing installation, allowing the new card adapters to be inserted into the existing adapters. In the case of system cabling with PLC/PLS transfer elements, only the DC cable and the PLC/PLS itself need to be replaced. MiBridge is compatible with PLC/PLS systems from different manufacturers.
