SPS IPC Drives 2017New products in Nuremberg
What new products will exhibitors be presenting at SPS IPC Drives 2017? Computer&AUTOMATION provides an overview of what can be seen in the Nuremberg exhibition halls this year.
The ESX-4CS-GW is the first product in the fourth generation of control units from Sensor-Technik Wiedemann. As a communication gateway, it offers six CAN interfaces, a 4-port Ethernet switch, a LIN interface and an RS232 interface. With an additional 14 analog and digital inputs and outputs in the standard configuration, the freely programmable controller can also take on small sensor-actuator management tasks. In the fourth generation of "ESX" controllers, the Infineon Aurix processor, which works with three independent 32-bit TriCore processor cores as a so-called "Triple-TriCore" with 300 MHz, ensures that tasks are processed quickly. The communication gateway fulfills the standards for conformity according to CE and E1 as well as the standards for the automotive, agricultural and construction machinery industries. Approval for safety-related applications in accordance with PLd (DIN EN ISO13489-1 2008-12) or SIL 2 (IEC 61508 Edition 2.0 2010-04) is planned. C" and IEC61131 are supported as programming languages. The respective development environments for this are Codesys and openSYDE.
