SPS IPC Drives 2017New products in Nuremberg
What new products will exhibitors be presenting at SPS IPC Drives 2017? Computer&AUTOMATION provides an overview of what can be seen in the Nuremberg exhibition halls this year.
The operating elements of Weidmüller's IT timer relay can be adjusted using standard tools. An LED display signals when the supply voltage is present, a switching time is running or the relay has picked up. The operating elements and display are housed in the flat front cover. The device, which measures just 57.9 mm × 17.5 mm × 98 mm (depth × width × height), even fits into small, machine-oriented on-site housings. It meets the product standards according to IEC 61812-1. The timing relay operates in an operating range of 24 to 48 V(DC) or 24 to 240 V(AC) and is therefore suitable both for classic contactor circuits and for applications that work with control voltages. Six time ranges cover a span of 0.05 s to 10 h; the repeat accuracy is <0.5 % or ±5 ms. With a switching capacity of 1250 VA(AC) (resistive) or 90 W(DC) (resistive), it can handle many switching tasks directly, without additional contactors. In addition to the standard 'on-delayed' and 'off-delayed with control contact', the device offers the functions 'on-delayed with control contact', 'on-switching voltage-controlled', 'off-switching with control contact', 'flasher pause-starting' and 'flip-flop' (toggle).
