SPS IPC Drives 2017New products in Nuremberg
What new products will exhibitors be presenting at SPS IPC Drives 2017? Computer&AUTOMATION provides an overview of what can be seen in the Nuremberg exhibition halls this year.
10 of 75
FMSC safety controller from Fiessler Elektronik
© Fiessler Elektronik
The FMSC (Fiessler Modular Safety Controller) from Fiessler with its modular concept can be flexibly adapted to the control task. Various master and slave devices are available for this purpose. Each "FMSC" module has twelve inputs, four safe outputs and five standard outputs. A two-digit display for initial diagnostics and a USB port for online diagnostics round off the hardware profile of the safety controller. The modules are plugged onto a top-hat rail; if several modules are to be used in one application, they are connected to each other using backplane bus connectors. Familiar functions have been adopted from the predecessor control unit "FPSC", such as the "shut down" function with a maximum switch-off time of 0.5 ms. What is new is that each input can now be parameterized for this function. This is done in the configurator of the "FMSC Studio" programming software. The safety controller can monitor up to 17 axes according to pl e. Another new feature is the parameterizable switch-off delay of the safe outputs.
10 of 75
