Hanover Fair 2016New products in Hanover
"Integrated Industry - Discover Solutions!" was the motto of the world's most important industrial trade fair, Hannover Messe 2016. Computer&AUTOMATION shows an excerpt of the products that were on display in Hanover in a picture gallery.
44 of 46
Regenerative power supply unit in two power levels from Lenze
© Lenze
Lenze is launching a regenerative unit in two power levels - with 12/24 and 26/48 KW. By separating the feed-in and regenerative paths, both branches can be designed separately, which enables exact dimensioning according to the system requirements. The regenerative power can be scaled by connecting several modules in parallel. According to the supplier, the compact regenerative feeder has an extremely short payback period thanks to its high efficiency and the absence of external filters. Retrofitting in existing machines is also possible. Typical areas of application are, for example, hoists, where a relatively high amount of energy is temporarily generated during the lowering of the load, as well as test benches, where the energy of the test object must be dissipated continuously due to the principle.
44 of 46
