Engineering
Günter Herkommer,
Hardware-independent visualization
With current web standards such as HTML5, CSS3 and JavaScript, the new Lasal VisuDesigner engineering tool from Sigmatek allows the creation of hardware-independent, user-friendly visualization solutions displayed on various HMI devices.
© Sigmatek
Thanks to an optimized browser, these also run smoothly on less powerful hardware. The graphic interfaces are designed and configured using modern design themes, as well as an extensive library of predefined controls. In the graphic editor, operating elements can be grouped into function units such as temperature zones and reused as desired. The logic behind the graphic elements can also be assembled from puzzle-like components without in-depth programming knowledge. Since the optics and logic of the control are separated, it is possible to easily create visualization projects in multiple display variations and load into other applications. Individually designed graphics and controls, animation, videos and audio files can be easily integrated. For machine concepts with option modules, the parameter sets of the currently available machine modules can be reloaded dynamically.
Codesys
Virtualized Control Technology in Practice
Software determines functionality in televisions, vehicles, smartphones, and increasingly in industrial automation and industrial control systems. This development has led to the emergence of virtual PLCs (vPLCs). The following article describes how...
Adlon
Security portfolio expanded
Adlon is further developing its Security Operations Center and adding another module to the existing Managed SOC for Microsoft 365 environments (based on Managed XDR): 'Managed SOC Advanced'.
Georg Schlegel
Compact, safe, self-monitoring
Georg Schlegel With the 'MKTOSFE' and 'MKPTOSFE' contact elements from the 'MK/MKP' series, Georg Schlegel is launching two compact solutions on the market that offer increased protection for man and machine in industrial applications thanks to...
