Logiccloud
The cloud-based PLC approach
A digitalized energy sector could become a central key to the energy transition. However, this requires existing structures to be broken up and rethought. Software-based cloud PLCs can be a crucial building block in this process.
Many industrial applications struggle to bring together information from distributed devices, systems or system components at a central point in order to optimally control or regulate the overall process. A pump storage power plant, for example, should start up when the energy operator needs it. For peak load optimization in production companies, various process parameters need to be balanced and adjusted accordingly. The much-discussed smart grid also requires decentralized information to be collected centrally and used to derive clever control algorithms. The same applies to load management at charging stations for transport companies, for example.
Breaking down old hierarchies
The main requirement here is to connect the physical level of a system or distributed system parts with a controller. In the past, this was a hardware controller that had to be installed at a specific location. However, these conventional, hierarchical structures no longer meet the requirements that digitalization places on control technology today. Bernhard Böhrer therefore founded Logiccloud three years ago: "Our idea was to bring the PLC itself into the cloud. The idea behind this is to collect distributed process information from the physical level via IoT technologies in the cloud and also control it from there. Artificial intelligence can be used to evaluate this data and derive process optimizations from it, which the digital control system then feeds back to the process. The savings potential would be immense."
The SPS - a service
Moving the control of a system to the cloud is met with skepticism by many automation engineers: necessary cycle times and safety are the main objections. However, many applications do not require short response times and are not safety-critical in the sense that a dangerous part of the system must be switched off quickly and reliably. Böhrer explains the key time data: "We achieve round-trip times of less than 100 ms, with 5G we are at around 10 ms and we can guess what will be possible with 6G. But even now, many projects can already be realized with the virtual PLC." The company currently offers the PLC in three versions: As a cloud solution, an on-premise solution and an edge device solution. All three variants can be programmed in the same way in the Logiccloud portal(Fig. 1). Whenever geographically distributed machines and systems or infrastructures need to be monitored, visualized and controlled, the cloud solution is the most suitable variant.
If you already have experience with PLC programming, you will quickly reach your goal with programming in the online portal. The controller is programmed in accordance with IEC 61131-3 using intuitive tools and AI-supported programming solutions; no special programming software is required. If important process data needs to be stored securely over a specified period of time, for example due to legal requirements or for statistical evaluations, it can be written directly to the Influx time series database. Grafana dashboards can be integrated directly into the visualization for evaluations (Fig. 2). The visualization itself can be created from a variety of widgets using a drag & drop designer with just a few mouse clicks. The widgets can be positioned freely and are not bound to predefined grids. The fact that PLC programs and HMIs can also be tested and simulated directly in the Logiccloud portal also speeds up and improves the programming process.
Compared to hardware-based control solutions, the software-based alternative offers advantages in terms of flexibility, scalability and efficiency. Because no hardware components need to be purchased and the controller runs virtually, individual adjustments to computing power, cycle time, availability or the number of read and write accesses are easily possible. The PLC is therefore scalable and can grow with the project and its requirements. This is also reflected in the costs, as controllers do not have to be oversized during installation in order to meet future requirements.
Flexibility and independence from proprietary solutions also result from the simple integration of distributed machines and plant components via standard protocols such as MQTT, Sparkplug B or OPC UA PubSub. In most cases, existing hardware from various manufacturers can be used to connect to the cloud without incurring additional VPN usage fees. If control updates need to be installed, this is often very time-consuming with hardware-based systems, whereas with software-based control, updates can be installed very easily, even across widely distributed systems (parts). The following application shows that some applications can often not be implemented at all with conventional solutions, or only with immense effort.
The virtual heating engineer
7 Business Consulting (7BC) sees great potential in virtually optimizing the control and maintenance of many of the heat pumps installed in Germany. By the end of the year, 7BC aims to detect faults in heating systems, reduce the energy consumption of heating systems by 20 percent, offer predictive maintenance for heating systems and integrate smart home functionalities. The company's vision is to control 100,000 heating systems by 2030. The aim is to use the electric car as a home energy storage system while still guaranteeing mobility. The plan is to supply 100,000 households with cheap electricity from the electricity exchange and support energy suppliers as smart grid partners for a secure electricity grid. This would reduce CO2 emissions by 750,000 tons per year and save 250 GWh of energy.
The company is pursuing a strategy that it calls "7 steps for a better climate". This involves logically linking the following elements: The hydraulics and electrics of the heat pumps with an ideal control system, predictive maintenance, the buildings, energy generation, the smart grid and the electricity exchange. To make this link possible, all relevant data must be collected at a central location and prepared in such a way that it can be further processed by artificial intelligence. The resulting parameters are then used to control the respective heating system. Jürgen Böhm, CEO of 7BC, explains: "We looked around the market. Implementing such a concept with conventional solutions is extremely complex, almost impossible. With the Logiccloud virtual control system, however, we were able to achieve initial results in just two days, which would have taken us weeks with conventional control technology." (hap/ah)
The authors: Nora Crocoll and Alex Homburg, Redaktionsbüro Stutensee.
