Small controls
Quelle: Akytec | Inka Krischke,
Can be mounted on top-hat rail without tools
The PRM extension module is an addition to the 'PR200' small controller from Akytec with the same performance as the basic device and eight additional digital inputs and outputs each.
© Akytec
Up to two extensions can be installed, which increases the potential of controllable processes. Depending on the supply voltage, the extension module is available with 24 V(DC) or 230 V(AC). The device in the compact housing can be installed on a 35 mm DIN top-hat rail without tools. Thanks to its design and depth, each module can be installed not only in the control cabinet but also in an electrical distribution board. It is connected to the base unit via an internal bus.
akYtec
Control portfolio expanded
AkYtec has new controllers, process displays and cloud services for industrial and building technology applications in its portfolio. The focus is on compact devices with integrated visualization and extended communication functions.
Codesys
Virtualized Control Technology in Practice
Software determines functionality in televisions, vehicles, smartphones, and increasingly in industrial automation and industrial control systems. This development has led to the emergence of virtual PLCs (vPLCs). The following article describes how...
