3D sensors
Quelle: Stemmer Imaging | Inka Krischke,
Blue LEDs with structured light
Stemmer Imaging presents the intelligent Gocator 3109 3D snapshot sensor from LMI. It is suitable for assembly lines, robot-guided 3D image capture and non-contact inspection of stationary objects.
© Stemmer Imaging
The projection scanner with blue LEDs comes in a housing measuring 49 mm × 100 mm × 155 mm and weighs less than 1.5 kg. This makes it ideal for mounting on robot arms. The sensor uses blue LEDs with structured light and stereo measurement techniques to realize high-resolution full-area scans with fast scan cycles of up to 5 Hz. The large field of view (86 mm × 67 mm to 88 mm × 93 mm) and flexible recording functions enable the measurement of a wide range of features such as fasteners, holes, grooves, bolts, gaps and offsets with just one 3D snapshot. The sensor communicates directly with programmable logic controllers or robots.
Block
Flexible three-phase power supplies
Block is expanding the 'Power Advanced' series to include three-phase switching power supplies. In addition to the single-phase power supply units already available, these variants offer a wide range of applications for industrial power supplies.
